Prevent Access to Telnet to my cisco router
avillalva Wed, 08/05/2009 - 22:46
Hi Neo,
just add the command transport input none on the vty lines.
i.e
conf t
line vty 0 4
Just make sure you have another method of administering it (such as console) before you add this.
HTH,
Andres
Richard Burts Thu, 08/06/2009 - 04:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Neo
I believe that we need some clarification of what you want to accomplish. The response from Andres assumes that you want to prevent any remote access. I am not clear whether you want to prevent all remote access or only prevent access by telnet. For example do you want to allow remote access by SSH? If so you could configure:
line vty 0 4
transport input ssh
and this would allow SSH and would prevent telnet. Also note that while vty 0 4 is the default for the number of vty that some routers provide more than 5 vty lines. So adjust your config to include all of the vty on your router. If your router had vty 5 and you only configure transport input ssh on 0 4, then a telnet to your router would succeed (it would bypass 0 4 and connect to 5).
Rick
