CSS management port connection problem
Aug 5th, 2009
Hi experts, I am configure a new CSS 11506. But I got the problem for accessing the management port. After connected between CSS mgmt port and a laptop, the CSS is unable to ping the tap. Does any expert know what is the problem? Is it related to speed/duplex issue?
ip add
subnet mask
Martin Kyrc Thu, 08/06/2009 - 04:15
Try reboot CSS box. I think, after changing mgmt ip configuration is necessary reboot box.
after that, let me know.
hfma_hk09 Thu, 08/06/2009 - 22:28
Hi Mkyrc,
The result is the same as before after rebooted Box. Any idea?
Gilles Dufour Fri, 08/07/2009 - 01:23
Do a 'show phy' on the CSS
CSS11503-2# sho phy
Configured Actual Partner Flow
Name Speed Duplex Speed Duplex Link Rev Auto Control
Ethernet-Mgmt 10 Mb/s half 10 Mb/s half Up 3 No -
See if the link is up.
I would not recommend to use this port unless you have very strict rules in your company.
You can manage the CSS using a regular port and it is easier to setup.
