AnyConnect configuration for Cisco VPN 3000
Aug 5th, 2009
Hello Experts,
Is there any solution, that I could use the Cisco Anyconnect with my existing VPN Concentrator 3000?
The motto behind it is since the Windows Vista 64 bit is not supporting VPN Client software, so was looking at Anyconnect, but documents says Anyconnect only support ASA with 8.0 code.
Please let me know if any workaround possible.
Arabinda
Collin Clark Thu, 08/06/2009 - 07:33
  • Purple, 4500 points or more
No work around, the 3000 does not support AnyConnect. You'll need to replace the 3000 with an ASA, which isn't a bad idea since the 3000 is EoL.
Hope that helps.
