Peter Paluch Thu, 08/06/2009 - 00:09
With CEF, even the first packet is switched. The CEF is built using the routing table as the source of information. Therefore, it is topology-driven and does not require actual packets to flow through the router as the normal route cache does.
This article is a wonderful overview of various switching methods in Cisco IOS, including CEF. Check it out!
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_white_paper09186a00800a62d9.shtml
Best regards,
Peter
Chetan Kumar Ress Thu, 08/06/2009 - 02:47
CEF is Packet forwarding Mechanism ………..
In simple words …… I can say It will Map your Entire routing table to Next Hop ………
So any User want to Communicate the packed will receive by router & it will see CEF table were to forward …….. The time for each packet will reduce ……… and your Packet forwarding will be fast ………..
