PIX VPN Redundancy
Hey guys,
I wonder if you can help me out with something that seems strange to me. I've got a PIX failover pair with VPN's to
two 6500 switches at our colocation. They use the same crypto map but different sequence numbers. This works fine and both come up but what seems to happen is that the far end initiates one and the near end the other.
That's cool as traffic seems to pass from near to far down one tunnel and vice versa via the other tunnel. My problem
comes when one goes down as the PIX only ever wants to route outbound packets down the first tunnel in the list. So, if this is the one that's down then it doesn't bother using the second one!
Is there a way I can fix this? I know I could just use two peers in the same crypto map statement but then I wouldn't
benefit from using both switches at the far end and spreading the load....
Here's what I have:
crypto map test 20 match address test
crypto map test 20 set peer 192.168.0.100
crypto map test 20 set transform-set test
crypto map test 20 set security-association lifetime seconds 28800
crypto map test 20 set security-association lifetime kilobytes 4608000
crypto map test 30 match address test
crypto map test 30 set peer 192.168.2.100
crypto map test 30 set transform-set test
crypto map test 30 set security-association lifetime seconds 28800
crypto map test 30 set security-association lifetime kilobytes 4608000
crypto map test interface outside
isakmp enable outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
tunnel-group 192.168.0.100 type ipsec-l2l
tunnel-group 192.168.0.100 ipsec-attributes
pre-shared-key *
tunnel-group 192.168.2.100 type ipsec-l2l
tunnel-group 192.168.2.100 ipsec-attributes
pre-shared-key *
access-list test line 1 extended permit ip 10.1.0.0 255.255.0.0 10.10.0.0 255.255.0.0
From show crypto isakamp sa:
1 IKE Peer: 192.168.0.100
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
2 IKE Peer: 192.168.2.100
Type : L2L Role : responder
Thanks for any help!
Anthony
