Extension Mobility Traces
Answered Question
Aug 6th, 2009
Hi Guys,
I have an isssue where I am struggling to generrate any trace files for Extn Mob.
I have gone through the configuration - set to detailed, Trace On, Enabled etc. and left the file settings as default. I have done this a couple of times but still no trace files.
This is on CUCM 4.3.
If anyone has any ideas I would be grateful.
Thanks in advance.
Chris
Correct Answer by gogasca about 7 years 11 months ago
Hi Chris,
Which folder and files you see?
Normally you need to see these files/
EMSvc*.txt
EMApp*.txt
Check EM service is enabled and started.
Make sure "Troubleshooting traces" for EM are not enabled only regular CUCM traces.
You can try restarting Tomcat if all above has been checked.
Overall Rating: 5 (1 ratings)
Correct Answer
gogasca Sun, 08/09/2009 - 13:48
  • Green, 3000 points or more
Hi Chris,
EMSvc*.txt
EMApp*.txt
ecclescf Mon, 08/10/2009 - 02:28
The stop/start of Tomcat has resolved the issue.
It looks like the cluster had been reconfigured in that the Extension Mobility service was only activated on one server.
Previously the service had been running on all servers in the cluster.
Many thanks for your post.
Cheers
Chris
