rmi error with cue script editor
Aug 6th, 2009
Hi to all,
i want use cue script editor to add a cusomt greeting to the voicemail but when i try to use it i get a rmi error(rmi op cannot accept calls made in rmi protocol 1.1. etc.etc.) the ip address to be specified in the Tools--->options menu is the one of the cue?( or something else?
Thanks and best regards,
Carlo S.
daysleeper Thu, 08/06/2009 - 03:02
It was an older version, now i have downloaded version 2.2.2....but is this the last version? There is something much updated?
daysleeper Thu, 08/06/2009 - 07:59
i have resolved searching in cisco.com....is so dispersive!!! Now is called Cuce editor....and it work!!!
I think i'm going to ask at this ask-cue how to create a proper script....it play the prompt one time and after that it stops....i want repeat the prompt at least 2 o 3 times before close the call.
