ACS 4.1 Password Validation details ?
Aug 6th, 2009
If changing the length of the Password length to 12, do the Users get informed when they try and log in and then are required to change their password to 12 characters ?
Jagdeep Gambhir Thu, 08/06/2009 - 05:47
  • Red, 2250 points or more
Answer to this is both yes and no :-)
Please provide more details about your network setup , type of authentication protocol used, how user's are connecting, what type of user's we have ? Type of user database we are using etc etc.......
~JG
florrieford Thu, 08/06/2009 - 05:58
Its the normal out of the box setup but we now require to change the Password Length to 12 instead of 8, so does ACS allow them to login and then inform them to change their passwords to a 12 length password ? Or do you have to pre warn them that it is going to be changed ?
Cheers
Florrie
