08-06-2009 03:14 AM - edited 03-06-2019 07:07 AM
Hello and PLZ Help Me
I tried to console to a VPN C 3005 using RS 232 cable with 2 DB 9 Female at both side (PC/SERIAL)-(VPN/CONSOLE) and Tuning Terminal Settings as Cisco described although I've attached to cat 5 cable to each interfaces (private-public) with green Light on interface led and system led alsoâ¦.so what's the problem ?I m Confused
thanks
08-08-2009 11:42 AM
any help here
08-08-2009 07:24 PM
Ali,
You may want to ask in the VPN forum as this query does not address any routing and switching component.
__
Edison
08-14-2009 11:22 AM
hello edison
its being long time..how r y?i hope y doing well...man i post there but i didn't get any good response there..anyways the VPN C Has a problem with console port
Thank y
08-14-2009 12:03 PM
Ali,
I'm doing well, thanks for asking. It has been a long time indeed and I'm glad to see you around.
The only thing I can recommend is checking this link:
If that fails, contact TAC for assistance.
HTH,
__
Edison.
