ACE no disk0: in context?
Aug 6th, 2009
I have a specific problem in virtual context.
I tried save capture file to disk0:, but it was full. ok, I deleted all files. There was no files, byt I have seen 9Mbytes used disk space (??). result: 11MB disk space, 9MB used, 2MB free... but there are no files!
How can I 'squeeze' disk0: in virtual context? I need 5MB space for capture.
Overall Rating: 5 (1 ratings)
Gilles Dufour Fri, 08/07/2009 - 02:06
  • Cisco Employee,
The disk0: is shared by all context.
1Mb is reserved and 10Mb available for all contexts.
Virtualization just prevents one context to access files from another context.
The 9Mb come from another context.
switch/Admin# dir disk0: | i used
4381696 bytes total used
switch/Admin# changeto User2
switch/User2# dir disk0: | i used
switch/User2#
As can be seen from above, the bytes used are he same for all contexts.
Gilles.
