How to configure two CISCO VWIC-1MFT-E1ports into a single pipe
Aug 6th, 2009
hi friends,
how can i configure the two CISCO VWIC-1MFT-E1 ports into single channel group
serial interface.i need both ports to work as one data pipe.
zeuscyril Thu, 08/06/2009 - 05:55
the above url giving the page you are searching is not available
Wilson Samuel Thu, 08/06/2009 - 05:37
Not sure if its E-1 PRI or E-1 (unframed/unframed) and the easiest way is to use PPP Multilink.
Here is one possible way to go for:
1. Make both the E-1 Interfaces use encap ppp
2. Create and Configure a Multilink Virtual Interface
3. Make the E-1 interfaces memeber of this Multilink Interface group.
And please find this as an example for the config
Above, all please let us know in case any help
Wilson Samuel
HTH, please rate if it helps
