FWSM 4.0 and CSM 3.2.2 sp2 interface renaming
Aug 6th, 2009
Hi I encounter and erro when I try to rename an interface of a context of FWSM 4.0 in transparent mode, through CSM 3.2.2 sp2: how to in CSM ?
I don't want to use CLI and import the context again.
thank you
vmoopeung Wed, 08/12/2009 - 09:05
In multiple context mode, to rename a context without changing the configuration is not supported.
You can save the configuration as a firewall configuration, but you need to copy the entire configuration to a new context name and delete the old context configuration.
r.spiandorello Fri, 09/18/2009 - 01:26
Hi, I don't need to change the context name but only the 2 vlan interface names of a bridge (couple of 2 interfaces) of one of the FWSM contexts.
Now the CSM is 3.3 version.
