ASA SSL Portal : Remove Application help
ccr_cisco
I've done some customization on the SSL Web portal on an ASA 8.2.
Everything's fine except I want to remove the help column on the right when I click on application.
See the attachment the column entitled 'Terminal Servers Help'
dominic.caron
Level 5
Level 5
Did you try leaving the help file blank ?
dominic.caron
Level 5
Level 5
Yes it works. so easy !
Thanks much.
roger.suqs
     Could you tell how to do!
