Loss dynamic user when I upgrade ACS 4.0 to 4.1
Aug 6th, 2009
When I upgrade from an ACS from version 4.0 to version 4.1 statics users are saved but dynamic are not saved.
This problem was detected in cisco?
Is there a way to export the database from version 4.0 to be able to import a version 4.1.
I have a big problem because they are 700 users dynamic edited manually.
Thank you very much.
vkapoor5 Wed, 08/12/2009 - 15:20
  • Bronze, 100 points or more
Dynamically mapped users are not saved when you perform replication, upgrade or overinstall ACS. Dynamically mapped users are saved when you back up or restore ACS.
"Performing a Full Upgrade From ACS SE 4.0.1 to ACS SE 4.1":
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.1/installation/guide/solution_engine/upgap.html#wp1111375
jose2r Thu, 08/13/2009 - 07:19
The ACS is not an appliance, it's the same?
Robert.N.Barrett_2 Fri, 08/14/2009 - 10:03
Just wondering why you care about the dynamic users? I thought that once they try to authenticate again, they will be re-added to the database.
