08-06-2009 07:27 AM - edited 03-04-2019 05:40 AM
My ASA 5510 have 5 light (Power, Status, active, VPN and flash) whan I turn on the ASA, the Power light is off, the active and status are in red adn VPN in green. Could you tell me, What can I do?
08-06-2009 08:19 AM
If there is nothing on the console ,it's best to open a TAC case.
08-06-2009 08:33 AM
Collin's right. According to this document:
The status light having an amber condition indicates that there's a problem, but it also says that an off power light means no power.
Verify that you have a good cable and a good power source by trying to take it somewhere else in your building, and other than that submit a tac case.
HTH,
John
