Remote vpn error
Aug 6th, 2009
i have these error while doing remote vpn to my network: Aug 06 12:18:59 [IKEv1]: Phase 1 failure: Mismatched attribute types for class Group Description: Rcv'd: Group 1 Cfg'd: Group 2
Attempt to get Phase 1 ID data failed while constructing ID
mcoroghidaf Sun, 08/09/2009 - 13:02
attached is the configuration:
thanks for the response. i have checked and checked and i seem not to be sighting the error. below is my config:
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-3des-md5 esp-aes esp-sha-hmac
crypto ipsec transform-set certvpn esp-aes esp-sha-hmac
crypto ipsec transform-set cert esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 20 set transform-set ESP-AES-128-SHA certvpn
crypto dynamic-map Outside_dyn_map 20 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 20 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 21 set transform-set certvpn
crypto dynamic-map Outside_dyn_map 21 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 21 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 31 set transform-set cert ESP-3DES-SHA ESP-3des-md5 certvpn
crypto dynamic-map Outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto dynamic-map Outside_dyn_map 40 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 40 set security-association lifetime kilobytes 4608000
crypto map Outside_map 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map Outside_map interface Outside
crypto ca trustpoint major
enrollment url http://major:80/certsrv/mscep/mscep.dll
subject-name CN=bng-asa.wcsa.com,OU=ict,O=wcsa lng,C=ng,St=la,L=hq
serial-number
keypair dmzca
crl configure
crypto ca certificate chain major
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 1000
authentication rsa-sig
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 1100
encryption aes
hash md5
group 1
lifetime 86400
crypto isakmp policy 65530
encryption aes
hash sha
group 5
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
group-policy defaultgroup internal
group-policy Defaultgroup internal
group-policy Defaultgroup attributes
default-domain value wcsa.com
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 10.13.200.113
address-pools value Certvpnip
tunnel-group DefaultRAGroup general-attributes
address-pool Certvpnip
address-pool certvpnip
authentication-server-group ACS LOCAL
tunnel-group DefaultRAGroup ipsec-attributes
trust-point major
tunnel-group wcsa_Remote type remote-access
tunnel-group wcsa_Remote general-attributes
address-pool wcsaVPN
accounting-server-group ACS
default-group-policy wcsa_Remote
tunnel-group wcsa_Remote ipsec-attributes
pre-shared-key *
tunnel-group defaultgroup type remote-access
tunnel-group defaultgroup general-attributes
tunnel-group defaultgroup ipsec-attributes
trust-point major
please, note that we have two tunnels and one is working perfectly, except fpr the CA one!
