BGP advertise-map with PL
Aug 6th, 2009
Hi Experts,
I am configuring BGP "aggregate-address advertise-map" command. Below is the config details for your kind reference
ip prefix-list FILT-PL seq 5 deny 3.1.11.0/24
ip prefix-list FILT-PL seq 10 permit 0.0.0.0/32
access-list 1 deny 3.1.11.0 0.0.0.255
access-list 1 permit any
route-map FILT permit 10
match ip address prefix-list FILT-PL
router bgp 200
no synchronization
bgp log-neighbor-changes
network 2.2.0.0 mask 255.255.255.0
network 2.2.1.0 mask 255.255.255.0
network 2.2.2.0 mask 255.255.255.0
network 2.2.3.0 mask 255.255.255.0
aggregate-address 3.1.0.0 255.255.240.0 as-set summary-only advertise-map FILT
neighbor 10.1.12.1 remote-as 100
neighbor 10.1.12.1 send-community
neighbor 10.1.12.1 route-map SAIRAM-NOEXP out
neighbor 10.1.23.3 remote-as 300
no auto-summary
When I use access-list 1, it working fine by not considering attributes of 3.1.11.0 network for aggregation.
Whereas if I use prefix-list FILT-PL it is not working, meaning it is taking the AS number of net 3.1.11.0 also in the aggregation.
I am confused why it is working when using ACL and not PREFIX-LIST
Thanks in advance
sairam
Overall Rating: 5 (1 ratings)
Peter Paluch Thu, 08/06/2009 - 10:24
  • Cisco Employee,
Sairam,
I haven't analyzed your configuration in detail right now but I see a problem in your prefix-list.
The second line says:
Obviously, you wanted to write something similar to "permit any". However, the correct syntax in prefix-lists for this is:
ip prefix-list FILT-PL seq 10 permit 0.0.0.0/0 le 32
In other words, any network (anything AND 0 = 0) with any mask (from /0 to /32).
Try it with this prefix-list and let us know if it worked for you.
Best regards,
Peter
snarayanaraju Thu, 08/06/2009 - 10:41
Hi Peter,
Thanks for correcting the configuration, it is working. Great
sairam
