Call Forward to Unity Connection failed
Aug 6th, 2009
I have cucm7 and uc7.
All phone can call voice mail pilot (which has tow ports) got proper response. Using message button on phones work as well.
But when phone A call phone B, no answer and busy calls dropped even though all CallForward setting on DN are pointed to VM.
Please help,
Overall Rating: 5 (5 ratings)
Jaime Valencia Thu, 08/06/2009 - 11:06
  • Cisco Employee,
  • Hall of Fame,
    2011
Are Phone A and VM ports in the same location and speak the same codec??
java
if this helps, please rate
smallrain_2 Thu, 08/06/2009 - 12:08
Yes. They have same codec.
Port Monitor (RTMT) on UC show no activity during the test call from phone A to B.
Jaime Valencia Thu, 08/06/2009 - 13:00
  • Cisco Employee,
  • Hall of Fame,
    2011
From A:
If you dial the VM pilot directly do you reach CUC??
You shouldn't be able to reach the VM ports directly if you followed the integration guides, but if you change the CSS to reach them do they take the call??
I would say check the routing rules but you mention you see nothing coming into the ports.
java
smallrain_2 Thu, 08/06/2009 - 13:13
Yes. All phones can reach UC by dialing pilot number and pressing message button.
User can set up voice mail passwe, gretting, etc.
But when two phone call each other, it did not forwarded to vm after no asnwer/busy.
Jaime Valencia Thu, 08/06/2009 - 14:04
  • Cisco Employee,
  • Hall of Fame,
    2011
There is no overlapping with the VM pilot and the VM ports DNs right?
I mean the VM pilot and VM ports do not have an identical DN
java
smallrain_2 Thu, 08/06/2009 - 17:30
They are unique. No overlapping numbers.
CFA was assigned with pilot number and port dn as a test. But still not forwarded to uc/vm.
Rob Huffman Fri, 08/07/2009 - 04:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Smallrain,
Hope all is well my friend! I think Java is onto something with the CSS reference (+5 points for Friday Java :)
Check the CSS assigned to your Call Forward settings (No answer,Busy etc.) to ensure that these CSS can reach the VoicemailPilotNumber partition.
Hope this helps!
Rob
Rob Huffman Fri, 08/07/2009 - 08:11
  • Hall of Fame,
    Founding Member
Hi Smallrain,
Great stuff my friend! Have an excellent weekend.
Cheers!
Rob
