ASA5505 x2 site to site and VPN Remote on same ASA
Aug 6th, 2009
Hello everyone,
Is it possible to create a site to site VPN tunnel between 2 ASA5505s and then create a Remote VPN server on one of them so that remote VPN users can connect to the LAN at the other end of the tunnel (local net access will I imagine be OK). I ask this because I have heard that you cannot do this on the ASA5505 because with the base license you can only have 1 outside interface.
Any pointers to such a configuration on the very extensive Cisco pages would be welcome. A simple corroboration or disagreement would also be very helpful.
Kind regards
