Swaooing DSP Modules
Aug 6th, 2009
Hello Everyone,
I have a 2811 and a 2801 that I need to swap DSP modules on. One is a bigger chip than the other. Other than gaining the additional resources on the router that needs the bigger chip is there anything I should look out for? This shouldn't really mess up anything right?
Thanks in advance! All replies rated
Overall Rating: 5 (2 ratings)
Nicholas Matthews Thu, 08/06/2009 - 12:56
You should be fine as long as you use the DSP calculator to make sure you have sufficient DSPs. Swapping isn't a problem at all, and you can mix-and-match as needed with any PVDM2-X module.
