4510R PoE
Answered Question
Aug 6th, 2009
  • Silver, 250 points or more
does any one knows if the 4510R supports PoE with power supply of 1400 watts?
Correct Answer by jbrenesj about 7 years 9 months ago
Actually,
The 1400 WAC (PWR C45-1400AC) DOES NOT provide PoE.
The 1400 WDC-P (PWR C45-1400DC-P) does provide poe but it's a DC PS
See Table 8. Cisco Catalyst 4500 E-Series Power-Supply Specifications (Data-Only Power Supplies)
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet09186a00801f3dd9.html
Also
See Table A-7 1400 W AC-Input Power Supply Specifications
Power over Ethernet: Not supported
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/0aspecs.html#wp1013080
- Jorge
Overall Rating: 5 (2 ratings)
Jon Marshall Thu, 08/06/2009 - 13:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Alejandro
Yes it does -
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/configuration/guide/PoE.html#wp1075873
You should use the power calculator for which there is a link in the doc above.
You can run the power supplies in redundant or combined mode. Combined mode means both power supplies are used to power devices. Obviously if one power supply fails you then lose power to devices.
Jon
Correct Answer
jbrenesj Thu, 08/06/2009 - 13:18
Actually,
Also
- Jorge
Jon Marshall Thu, 08/06/2009 - 13:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jorge
Thanks for pointing that out, my mistake.
Alejandro
Apologies for the incorrect information.
Jon
jbrenesj Thu, 08/06/2009 - 13:38
Don't worry, it happens because there are two flavors of 1400W... it's always confusing
