Jaime Valencia Thu, 08/06/2009 - 13:06
  • Cisco Employee,
  • Hall of Fame,
    2011
Only on H323 GWs, NOT possible with MGCP
Reject Calls
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
PLEASE search previous posts, there are plenty of posts with the same question
java
if this helps, please rate
KonradStepniewski Fri, 08/07/2009 - 01:16
  • Silver, 250 points or more
What about blocking patterens in CUCM? IMO you can block any number you want, range of numbers as you can create pattern and block it. Outgoing calls ofc.
Edit: Ok he talks about incoming calls probably. ;)
