redue ICMP reply on ASA
Aug 6th, 2009
I would like to know how I can reduce the about of ping reply a ASA can reply. I have a ASA 5520 and need to only let 4 ping reply in.
wdrootz Wed, 08/12/2009 - 13:14
You can change the "Repeat count" parameter to 4 in the "ping" command. Below is the syntax of ping command.
ping [if_name] host [data pattern] [repeat count] [size bytes] [timeout seconds] [validate]
suschoud Wed, 08/12/2009 - 13:26
not possible.
you can control the no. of icmp unreachables generated by asa,not echo replies.
you can totally deny firewall to respond to any ip via
icmp deny " command.
