08-06-2009 02:17 PM - edited 03-18-2019 11:29 PM
I am getting this below alert from the RTMT tool and the version of my CUCM is 6.1 .I wanted to know why this alert is getting generated when my network is stable without any outage.
Number of registered phones in the cluster drops 3 Percent. Current monitored precanned object has decreased by 8 percent. The alert is generated on Thu Aug 06 15:36:30 EDT 2009 on cluster StandAloneCluster.
08-06-2009 07:52 PM
well it does indicate what is says it does,
3 percent has unregistered, if you know the total amount of phone, you should be able to ascertain, how many phones dropped and work out which location was experiencing the issue.
08-07-2009 05:49 AM
Thanks,but then is there a way to get more specfic information from the RTMT about the unregistered phones,primarily the location of the phones that is unregistered ???
08-10-2009 04:01 PM
You can try to locate the location of the unregistered phones on the event viewer of the CM server/s. There will probably many errors there about which ip address of phones that has unregistered.
Also (if possbile) try to setup a syslog server so may know if this is/are caused by the network issue.
and yeah, there must be a log/logs in the CM(CUCM) server about the unregistering of the phones. Hopefully someone will enlighten us...
rgds
08-14-2009 08:24 AM
Hi rgds,Tks for the reply.The version of CUCM iam running is 6.1.3 and its on Luni platform,andi hope we dont have the concept od event viewer anymore.Can anyone share your views on
1. "how to get the specific inforamtion (for example IP address of the phone) from the RTMT unregistered alert ???
2.A way to add some some specific information in the RTMT alert tool to show the Ip address of the Phones when an unregistered phone alert is generated.
Immediate reply for these questions is highly appericiated.
