ospf limitation on cisco router.
Aug 6th, 2009
hi..
I heard that the limitation of ospf on cisco was in there. for example, the number of area, and the max number of ospf process per device.
I has knew that ospf in cisco can configure up to 32 ospf process, Is it right?
and more in the ospf limitation , please tell me about it. Thank you.
Jerry Ye Thu, 08/06/2009 - 18:38
  • Cisco Employee,
Hi Sung,
The OSPF limitation is the amount of memory and cpu power of the router. It is because the nature of OSPF, where an route update will cause the all OSPF routers to recalculate the cost with the Dijkstra's algorithm, and it is very CPU intensive.
I will suggest you to take a look at this document
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml#t39
HTH,
jerry
