BGP Route Advertisement Question
Answered Question
Aug 6th, 2009
I'm sorry if this is kind of long. I'm sure there's a simple answer. Hoping someone can shed some light:
Let's say the “major” network for my site is 10.11.0.0 /16
Let's say I had an interface that I sub'd out into 3 vlans. (gig1/0 sub'd into g1/0.10, g1/0.20 & g1/0.30)
Networks are
vlan 10 = 10.11.0.0 /24
vlan 20 = 10.11.1.0 /24
vlan 30 = 10.11.2.0 /24
I have 2 different bgp peers I want to advertise networks to.
One peer I want to advertise the whole 10.11.0.0 /16. The other peer I only want to advertise 10.11.2.0 /24.
Regarding the peer that I wanted to advertise 10.11.0.0 /16, I noticed that I couldn't just put "network 10.11.0.0 mask 255.255.0.0" under my “router bgp” section of the config. I didn't have any loopback interfaces with any 10.11.0.0 /16 IP's assigned to them. Nor did I have “redistribute connected” within my “router bgp” section of the config.
So I generated the router by adding a static route to Null 0. (ip route 10.11.0.0 255.255.0.0 null 0) then I added the command “redistribute static” under the “router bgp” portion of the config. By doing this, I was able to generate the 10.11.0.0 /16 route. (NOTE, I haven't or didn't need to add the “network 10.11.0.0 mask 255.255.0.0” statement under the “router bgp portion of my config.)
So now I am sending my 10.11.0.0 /16 route to the peer accepting my 10.11.0.0 /16 advertisement.
I want to send ONLY the 10.11.2.0 /24 to my other peer.
I was able to do this by simply adding the statement “redistribute connected” under the “router bgp” portion of my config. (Easy enough) BUT my question is…..is there a way to advertise my 10.11.2.0 /24 to the peer who wants to see it, without using the “redistribute connected” command?
And secondly, if I were to add the network statement under my “router bgp” for the 10.11.0.0 /16, could I also add the 10.11.2.0 /24 network statement under router bgp? (And removing the redistribute connected statement.)
Is there a way to advertise routes to different BGP peers without using redistribute static and/or redistribute connected?
So it would look like
Router bgp 65425
network 10.11.2.0 mask 255.255.255.0
Your input is greatly appreciated
Correct Answer by Jerry Ye about 7 years 6 months ago
Hi Jesse,
BGP is a very special protocol, routes need to be exist in the routing table, via IGP, connected, static, before it can advertise into BGP.
So your solution of advertising 10.11.0.0/16 into the BGP by adding a static route with the command ip route 10.11.0.0 255.255.0.0 null0 is one way to do it.
jerry
Overall Rating: 5 (1 ratings)
Jerry Ye Thu, 08/06/2009 - 18:48
Hi Jesse,
You can use prefix-list under your neighbor command to control what to advertise to each of the BGP neighbor. For example
router bgp 65425
neighbor a.b.c.d remote-as aaaa
neighbor a.b.c.d prefix-list SLASH16 out
neighbor w.x.y.z remote-as wwww
neighbor w.x.y.z prefix-list SLASH24 out
ip prefix-list SLASH16 permit 10.11.0.0/16
ip prefix-list SLASH24 permit 10.11.2.0/24
HTH,
jerry
mortonjes Thu, 08/06/2009 - 18:57
Hi Jerry, thank you for taking the time to reply.
My understanding of pre-fix lists, is that they are for controlling what routes are allowed to be advertised and what routes are not. (filter)
With regards to the example in your reply, I see that you have listed the networks 10.11.0.0 /16 and 10.11.2.0 /24 as "network" statements withing BGP but, without having a static route and redistributing it into BGP (and/or) redistributing "connected" into BGP, how are you / how would you be generating the routes?
(I hope I'm making sense.)
Thanks again.
Jesse
Correct Answer
Jerry Ye Thu, 08/06/2009 - 19:03
Hi Jesse,
jerry
