presence Failed to connect to CUCM Dbmon
Aug 6th, 2009
  • Blue, 1500 points or more
I have noticed on a number of occasion that syncing between CUCM and CUPS is not functioning properly.
for instance when I want to add a CUPC user, and I add the licence to that specific user in CUCM, it is not replicated to CUPS (the CUPC licence field is nojt ticked in CUPS).
when i manually restart the sync agent in CUPS, it forces a resync and most of the times this cascades down to CUPS).
In the tracelog of CUPS i do read the following output:
at com.cisco.ccm.util.ncs.NcsClient.connect(NcsClient.java:270)
at com.cisco.ccm.util.ncs.NcsClient$ReceiveThread.run(NcsClient.java:354)
2009-08-07 12:30:52,587 ERROR [Thread-5] sync.DbmonClient - Failed to connect to CUCM Dbmon.
2009-08-07 12:34:31,591 ERROR [Thread-5] ncs.NcsClient - NcsClient:[email protected] IOExc : java.net.ConnectException: Connection timed out
This allthough the sync agent troubleshooter in diagnostics in CUPS shows no signs of issues (all green)
anybody experienced similar issues
Overall Rating: 4 (1 ratings)
htluo Fri, 08/07/2009 - 05:26
  • Red, 2250 points or more
This is called "change notification failure". You need ClusterManager logs to troubleshoot.
Possible causes include (but not limited to):
1) CUCM's hostname is not in CUPS' host table.
2) CUPS' secrete password does not match with CUCM cluster.
3) Host name/IP address was changed on CUCM after CUPS was installed.
Michael
http://htluo.blogspot.com
snicklas Thu, 08/26/2010 - 12:04
Was the hostname mismatch for me.  Thanks.
