CSA and okclient.exe error during logons
Aug 7th, 2009
I am getting this error everytime we login to a W2K3 R2 SP2 system. I have tried the following:
-Uninstall and re-install the CSA client
-Checked Windows Services for the CSA service logon properties and it is set to local system account
-Disbaled CSA from the startup menu, rebooted. The error message did not appear at startup.
The CSA service (CSAControl.exe) starts Automatically at boot up without the okclient.exe running at startup. however
When I launch the okclient manaually after a reboot, the error returns. (The application failed to initialize properly (0XC06d004e).
Does anyone have any ideas on how to fix this?
tsteger1 Fri, 08/07/2009 - 10:50
Need more information to make a guess.
Did it ever work?
Do you have a policy preventing the Agent UI?
Any event log errors?
Is it 64 bit Windows?
Do you have similar servers where it does work?
CSA version?
Log on as a different user?
Information from the CSAgent-Install.log and driver_install.log may be useful.
Tom
niall-wilkins Tue, 08/11/2009 - 10:04
Hi sorry here is some more info:
-Its never worked as it is a new Installation of CSA version
-Its 32 Bit Windows
-CSA version is 5.1.0
-Error happens no matter what user logs into the system. CSA flag does not run in system tray either.
I do see the following that is suspicous
[2009-08-11 08:01:16.640] [PID=888] [Csamanager]: Failed to initialize Windows Firewall, error: 0x800706d9
[2009-08-11 08:01:16.640] [PID=888] [Csamanager]: Failed to update Windows Firewall status after 80 seconds, error: 0x800706d9 - The method failed because the Windows Firewall, Internet Sharing Service (SharedAccess) was not running.
[2009-08-11 08:01:18.625] [PID=888] [Csamanager]: Failed to update CSA registration with Windows Security Center after 80 seconds (5 attempts), error: 0x8004100e - Namespace specified could not be found. Possible cause: SecurityCenter interface is not registered with the system; WMI repository may need to be rebuild.
I have attached some of the log files.
tsteger1 Tue, 08/11/2009 - 12:32
It looks like you don't have a rule allowing the agent UI to run on that host.
[2009-08-11 08:01:00.109] [PID=4264] [AgentUI]: AgentUI starting... [secure]
[2009-08-11 08:01:00.156] [PID=4264] [AgentUI]: Agent UI is not allowed to run. Will exit.
[2009-08-11 08:01:00.156] [PID=4264] [AgentUI]: AgentUI exiting
If you don't have one allowing it, it won't be able to run.
Tom
