switch ingress policy drops
Aug 7th, 2009
  • Silver, 250 points or more
I am seeing a lot of drops on the interface connected to the inside network. The sh int command reveals a lot of "switch ingress policy drops". What causes it and can be it be fixed?
The ASA 5505 is running ver 7.24
rgds,
Yudong Wu Fri, 08/07/2009 - 11:47
  • Gold, 750 points or more
Are user reporting any performance issue?
If not, check the following bug.
CSCsz33819 "switch ingress policy drops" are corrupted every 65535 packets
Tshi M Wed, 08/12/2009 - 04:00
No, users are not reporting any performance issues. I recently upgraded its software to release 8.0(4) release August 10 2008 but that did not seem to resolve the problem.
Tshi M Wed, 08/12/2009 - 06:52
Thanks much for the quick reply. None of the mentioned applied to my situation. Please see below:
ASA5505
interface Vlan50
nameif inside
security-level 100
ip address 10.64.50.15 255.255.255.0
interface Ethernet0/1
description Uplink to gig0/40 on Core
switchport access vlan 50
speed 100
duplex full
Switch
interface Vlan50
ip address 10.64.50.254 255.255.255.0
interface GigabitEthernet0/40
description to e1 on IF1
switchport mode access
load-interval 30
speed 100
duplex full
Yudong Wu Wed, 08/12/2009 - 06:59
You'd better to sniffer the packet on switch port via SPAN to see what kind of packets are sending to ASA.
Tshi M Thu, 08/13/2009 - 06:16
I couldn't find anything there either. I checked other forums and find out quite of number folks reporting this issue with the ASA5505 which lead to me believe it is a problem with the hardware software and nothing else. It would be great to know when this is fixed.
Yudong Wu Thu, 08/13/2009 - 07:31
Not sure if you have verified this -- ethernet keepalive.
1. change keepalive to 20 sec on switch port.
2. on ASA check "show controller ethernet x/y | i Filtered" to see if the ingress filtered number is incrementing in the same speed as keepalive.
Anyway, if it won't impact the traffic, it should be OK. I did not find any new bug regarding to this so far.
