IOS 12.2 SUP720 bootvar how to change
I have a SUP720-3BXL with the following
bootentrie in running and startup-config
boot system sup-bootflash:s72033-advipservicesk9_wan-mz.122-33.SXH5.bin
After reloading the switchs falls into
rommon mode; after booting manually from rommon an typing
sh bootvar
i get the following output
BOOT variable = disk1:s72033-advipservicesk9_wan-mz.122-33.SXH3.bin,12;disk1:s72033-advipservicesk9_wan-vz.122-33.SXH3.bin,12;sup-bootdisk:/newsys/s72033/base/s72033-advipservicesk9_wan-vm,12;
CONFIG_FILE variable =
BOOTLDR variable =
THE NEW bootentry in running and startup
config seeems to be ignored ! How can I overwrite the bootvar in order to get an
automatic boot ?
Lucien Avramov
Level 10
Level 10
router(config)#no boot sys
router(config)#boot sys disk1:image_name
no boot sys will clear all the previous entry for the image names and then just add the one you want to boot with.
Thanks for your reply;
I have cleared the bootvariables before
reload; nevertheless the old bootvar
appears again after my manual reload
from rommon. Sigh!
Edison Ortiz
Are you sure the file is on sup-bootflash?
That media is usually small and it wouldn't fit a large file such as the one from SXH5.
Can you post the directory structure from sup-bootflash along with disk1 with the command:
dir sup-bootflash:
dir disk1:
If the file isn't there, that's the reason is failing.
HTH,
__
Edison.
I have a WS-C-UPG-1GB= installed
in my sub720. Verify on my new system
image file stored on this medium results
in an ok state.
