Unity failover server warning
Aug 7th, 2009
warning
event id 1023
Unable to forward System NDR to unaddressedmessages. The NDR is deleted from the Unity System Mailbox
I have been getting about 6 or 8 in a row for a few weeks
It may be causing my issue where when we failover the server, if someone has a saved voicemail, the unity failover server treats it like a new voicemail message and the MWI comes on. Users can only get the message if they listen to saved messages.
Has anyone seen this before?
drolemc Thu, 08/13/2009 - 10:42
  • Silver, 250 points or more
On the NDR errors, the message means that it could not deliver a notification that a message was undeliverable.
This is most likely because the system account' mailbox that you have configured to receive system messages is full.
Check the mailbox of UNITY_SERVER or whatever you have configured to receive notifications.
You can open this mailbox and delete those messages.
The only parameter that controls the target for NDR messages is the registry key.
So you can create new DL change that registry key and restart Unity for a change to take effect.
