ASA w/L2L Ipsec tunnel & 8 IP Phones connecting 2 CM thru Tunnel with Skinn
Aug 7th, 2009
I have an ASA installed at a remote office connected to internet doing Nat. I now need help getting the IP Phones to talk to a call manager server that is located thru the tunnel. Call Manager and phones are to use skinny. They will all be connected to a 2940 Switch. Would you recommend a separate Vlan for the voice traffic? What if anything special do I need to enable on the ASA to make this work? Any Docs with a config like this? I cant seem to locate exactly what I need.
