Cisco Callconnector server/mobility Server Wizard is not supported on virtual machines?
Aug 7th, 2009
I was installed the server software on our server last night and ran into this problem.  A popup window stated very clearly that the setup wizard is not supported on virtual machines.  It appeared as though the software was running properly (most services started) on the server (from what I could see), but I could not configure the server.  Is there a different way to configure the server-end software other than the wizard?  We are running VMWare ESXi 3.5 in our Production facility if that helps in any way.
Thanks in advance,
Seth
David Trad Fri, 08/07/2009 - 15:49
Hi Seth,
Technically it is not supported in VM mode, however some people have been doing work-ups in a lab enviroment and have successfully got it to work, i am also presently working on this as well.
Have a look at this:
https://www.myciscocommunity.com/thread/2086
Once i find a way for it to work stably i will post proceedures up for others to give it a try.
Cheers,
David.
