Need Help with FWSM on 6500 and removing a vlan from FWSM
Aug 7th, 2009
I created a vlan 102 on the 6500 and then added it to vlangroup 1 and set it up to the FWSM with "firewall module 7 vlan-group 1". I then created the SVI on the FWSM with the IP and Stanby IP as I have a active and standby blade in 2 different chassis.
Now I need to delete the VLan 102 from the FWSM and the vlan group 1.
I was able to delete the interface but cannot delete the vlan 102 from the vlan group...
How is this done?
sudheesh.pb Fri, 08/07/2009 - 23:09
To Delete the Vlan from Vlan Group 1, use the following commands in your 6500,
no firewall vlan-group 1 102
This will remove only vlan 102 from the list.
Try this and respond.
