CM7.1, EM, and AD
Aug 7th, 2009
I have CM7,1 with AD integration/authentication. Looking to configure EM. I prefer to have user login with their extension, rather than name. I have alphanumeric number set to false, so I can type the users phone number in login page, but cant authenticate. I believe its because the username is different, due to the AD integration. Is this possible? Thanks
Anonymous (not verified) Thu, 08/13/2009 - 08:36
Once you sync with the telephoneNumber in LDAP, then you have login with the telephone number User ID for both EM and ccmuser.
The "LDAP Attribute for User ID" is used to select which AD user attribute is to be set as the user ID in the CallManager.
sAMAccountName -> 'User Logon Name' under the Account attribute for the user
telephoneNumber -> 'Telephone number' under the General attribute for the user
If the LDAP userID attribute is changed from sAMAccountName to telephoneNumber, this would then force user IDs to be synced to the telephone numbers. Hence, users will authenticate/login to EM and ccmuser with their phone number.
It can be chosen whether the 'Phone Number' in UCM (LDAP - > Directory) maps to TelephoneNumber or ipPhone in AD.
telephoneNumber -> 'Telephone number' under the General attribute for the user ipPhone -> 'IP phone' under the Telephones attribute for the user
If currently using the ipPhone field in synchronization with LDAP/AD, then the telphone number in the user page will display the corresponding ipPhone value. For example :
First name : Cisco
Last name : Tac
Telephone number : 1000
IP Phone : 2000
LDAP synced with 'telephoneNumber' (under LDAP -> System), and 'Phone Number' synced to value 'ipPhone'. This will result in
User ID : 1000
First name of User : Cisco
Last name of User : Tac
Telephone number of the User : 2000
However, the user ID is the same, whether to login to EM or use the ccmuser page. So once you sync with the telephoneNumber in LDAP, then you have login with the telephone number User ID for both EM and ccmuser.
