Custom Wallboard - SQL Help for lost AgentStateDetail records
Aug 7th, 2009
I've got a custom-written wallboard to monitor agents and traffic real-time. When I change the Agent competence level or remove a skill, the agent's records are no longer available in the AgentStateDetail table. Because of this, the agent's status is unknown until there is a new status change generated by the CAD agent (a new entry in AgentStateDetail is then created). Is there a way around this?
Cisco Unified CCX Premium - 7.0(1)SR03_Build011 HA
ivillegas Thu, 08/13/2009 - 11:07
As soon as the change to agent is made via CCM or LDAP, click on the Resources link in AppAdmin or try to restart the CRS engine.
joe.conger Thu, 08/13/2009 - 12:07
The Agent resourceID changes in the Resource table whenever you modify the agent skills. I had an inner join with the AgentStateDetail.agentID to Resource.resourceID that would fail due the the new resourceID for the agent.
Thanks for your help
