How to reset the Blocker
Mickelkel
I made a mistake in configuring the listeners of the Blocker , I unchecked services on the listener interface both incoming and outgoing.
So now the management ip of the unit is pingable but no services are available. Is there a way to reset it to default physically ?
Thank you
Mickekel
12 Replies 12
bethingt
Unfortunately there is no reset button for the Blocker. Did you disable all services? If telnet is still enable you can turn back on the services that way.
Brian
Yes i disable all the services on both interfaces, and the only open port is SMTP on the outgoing interface (Nmap port scanning).
What can i do ?
dzavasni
Hi Mickekel,
I assume you've nmap'd both interfaces?
All methods of resetting the blocker require one of those management ports to be open. I have tried connecting to the serial port and I am not getting any response from it. In the off-chance that the Blocker I'm using in the lab simply has a bad serial port, you can try using these settings in your preferred terminal emulator (HyperTerminal, Putty, etc...):
Bits per second: 9600
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Hardware (RTS/CTS, DSR/DTR)
If you gain access, you can turn on the management services for the interface of your choice by typing "interfaceconfig," and following the prompts.
If this does not work for you, we will need to look into an RMA.
Hi dzavasni,
Yes I scanned the two listeners
I willl try to do it in 3 weeks when i will be back from holidays.
I hope your solution works.This would help to reset the  box easily in this kind of situation.
Thank you
In the event network connectivity is not an option for administering your Blocker appliance, you may also connect directly to the unit's COM port using a null modem cable (9-pin serial) in order to establish a command line interface (CLI) session.  This is particularly useful during the initial configuration process of the device.  In order to proceed, you will need the following:
    *  9-pin female-to-female serial cable (null modem)
    *  Serial console client (such as HyperTerminal or PuTTY)
Please use the following procedure as a guide:
   1. Connect your laptop (or other client device) to the serial port on the back of the unit using a standard 9-pin null modem cable.
   2.  Launch your preferred serial console client. Specify the appropriate COM port to use on your local machine, and use the following settings for the connection:
      Data bits: 8
      Parity: None
      Stop bits: 1
   3. Once the session has been opened, you may need to press Enter a few times to trigger output. A log in screen should appear.
   4. Log in using your appropriate credentials.
Once you are in the Blocker follow the following example to enable services on which ever interface you wish.
mail.example.com> interfaceconfig
Currently configured interfaces:
1. Management (172.19.0.80/24: mail.example.com)
Choose the operation you want to perform:
- NEW - Create a new interface.
- EDIT - Modify an interface.
- GROUPS - Define interface groups.
- DELETE - Remove an interface.
[]> edit
Enter the number of the interface you wish to edit.
[]> 1
IP interface name (Ex: "InternalNet"):
[Management]>
IP Address (Ex: 192.168.1.2):
[172.19.0.80]>
Ethernet interface:
1. Data 1
2. Data 2
3. Management
[3]>
Netmask (Ex: "255.255.255.0" or "0xffffff00"):
[0xffffff00]>
Hostname:
[jessie.run]>
Do you want to enable FTP on this interface? [N]>
Do you want to enable Telnet on this interface? [N]>
Do you want to enable SSH on this interface? [N]> Y
Which port do you want to use for SSH?
[22]>
Do you want to enable HTTP on this interface? [N]> Y
Which port do you want to use for HTTP?
[80]>
Do you want to enable HTTPS on this interface? [N]>
You have edited the interface you are currently logged into. Are you sure you want to change it? [Y]>
mail.example.com> commit
Hope this helps!!!!
Brian
Hello Brian,
Sorry for the response time but i come back from holiday
Your solution works perfectly !!!
Thank you for your help
Mickelkel
Jo Kern
and waht can I do when I also misplaced my login credentials ?
Is there a way to set it to factory default or to recover the admin assword ?
Jo
Unfortunately there is no reset that you can do if you have forgotten or misplaced your login information. You will need to contact Cisco Small Business Support and open a case so that we can reset your login information.
Hi All,
And what to do if we get errors while trying to reset the blocker...
When we try to do it through webUi we get(error in the attachement).
When we try to do it through CLI, we get:
cisco.example.com>
cisco.example.com> resetconfig
The resetconfig command only works in the offline state.  Type 'suspend' to
go offline.
cisco.example.com> suspend
Enter the number of seconds to wait before abruptly closing connections.
[30]> 0
Traceback (most recent call last):
  File "pycbox_main.py", line 157, in
  File "/data/lib/python2.5/imputil.py", line 103, in _import_hook
  File "/data/lib/python2.5/imputil.py", line 192, in _import_top_module
  File "/data/lib/python2.5/imputil.py", line 219, in import_top
  File "/data/lib/python2.5/imputil.py", line 274, in _import_one
  File "/data/lib/python2.5/imputil.py", line 305, in _process_result
  File "./phoebe/cli/cli.py", line 33903, in
  File "./phoebe/cli/cli.py", line 25974, in main
  File "./phoebe/cli/cli.py", line 649, in command_loop
  File "./phoebe/cli/cli.py", line 32071, in do_command
  File "./phoebe/cli/cli.py", line 32322, in main_input_run
  File "./phoebe/cli/cli.py", line 32084, in run_func
  File "./phoebe/cli/cli.py", line 9421, in suspend
  File "./phoebe/cli/cli.py", line 9405, in _suspend
  File "./phoebe/cli/cli.py", line 21210, in _suspendlistener
AttributeError: 'str' object has no attribute 'keys'
AsyncOS cisco.example.com (cuad0)
login:
The blocker won't go to the suspend state due to mentioned errors.
What can be done to get such blocker working?
That blocker is testing unit that got back from tests at our partner.
Best Regards,
Lukasz
Try the suspend again but this time do not give a value of 0 maybe allow the max, 30.
Brian
Hi Brian,
Thank you for suggestion, unfortunately we still get the same error:
cisco.example.com>
[30]> 30
login:
Lukasz
I would sugest calling Cisco Small Buissness Support Center and opening a case with us so we can troubleshoot this for you.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html#csb
Brian
