Can't establish RDP connection over IPSec L2L VPN
Aug 7th, 2009
Got 2 ASA 5505 connected to each other via L2L IPsecVPN. I can RDP a server from my remote location to HQ site but cant RDP from HQ to remote site. VPN is up and running ok. I can ping any server from both sites. I have attached running configs from both ASA5505. Public IP Address and relevant names on the configuration were omitted. Any feedback is highly appreciated.
udimpas
sadbulali Thu, 08/13/2009 - 10:25
windows firewall would have got RDP out of its exeption list. As soon as we checked the box you would be able to connect.
net.administrat... Fri, 08/14/2009 - 01:46
You shouldn't need to add the explicit line for RDP as it will be covered by the IP line you have:
access-list outside_1_cryptomap_1 extended permit ip inside 255.255.255.0 172.16.1.0 255.255.255.0
Its difficult to read this you have cut the access-group statement from the remote site config.
try adding
access-list inside_access_in extended permit tcp any any eq 3389
to the HQ firewall.
I believe there is a sysopt command that allows you to bypass these lists for site-site vpn but never quite got it to work myself.
Do you get any syslog error messages, these can be helpful.
