Slow upload speeds to Internet via ASA 5520.
Aug 8th, 2009
I'm pretty sure this is a firewall issue, let me explain the issue I have.
Setup:
We have 2 ASA 5520's in Active/standby mode. The 'outside' port it connected to a VLAN on a 3750 switch where our 50mb lease line is (ISP Cisco router). The 'inside' of the ASA goes into another VLAN on the 3750 switch where our internal LAN switches are. On this 3750 switch there are various other VLANs that are sub-interfaces on the ASA via the trunk from the 3750 to ASA.
I've been running some speed test for our Internet lease line out of hours. It is a 50mb line and download speeds are around the 47mb mark which is fine.
I'm using http://speed.redstonemanaged.co.uk/ and http://www.speedtest.net/
Now the issue, the upload speeds are only ever 8-11mb and I have tried it on variuos different location on the internal LAN and get the same results.
If I go onto a server in a VLAN on the 3750 switch again I get the same issue, as the servers travel via the trunk to the ASA and out to the 'outside' interface to the VLAN where the Internet router is.
Now if I put a laptop directly into this outside VLAN on the 3750 where our 'outside' interface of the ASA is and ISP router then I get an upload of 47mb! I had to give the laptop a public IP and the gateway of the ISP router.
It just seems anything that has to pass through the firewall it has an slow issue transmitting/uploading data outbound to the Internet.
Our ASA also have the IPS module, I turned this off and it made little difference. To turn the module off (only way I know) is to use Cisco IPS Manager Express > confgiuration > Event Action Rules > Rules0 > disable event action. Also on the ASA usign the ASDM I went to Service Policy Rules and unticked the interfaces to monitor.
Can you thing of any other steps I can do? Is it a NAT/PAT issue? I am lost for ideas.
v.shearer Tue, 08/11/2009 - 05:54
I am getting the same issue with 5520's in active/standby running 8.2(1). 25Mbit dedicated link and get 20-27Mbit download and 8-11 upload.
whiteford Tue, 08/11/2009 - 05:57
If I run the tests infront of the ASA's then it is fine, could it be a bottleneck? I thought maybe it's badly configured rules or NAT's.
suschoud Tue, 08/11/2009 - 15:45
  • Gold, 750 points or more
try bypassing the ips,that is do not send traffic to ips module.
it is done using commands within asa.
m not sure what ur config is/
please paste " sh run policy-map " command o/put.I'll get the speed up. :)
hTH
sUSHil
whiteford Tue, 08/11/2009 - 22:57
I did try bypassing the IPS already, but could be doig it wrong as the upload speed was still 10mb or so.
Here is my output:
sh run policy-map
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
inspect ils
inspect pptp
inspect icmp
inspect icmp error
policy-map DMZ1Servers-policy
class DMZ1Servers-class1
ips inline fail-open sensor vs0
policy-map outside-policy
class outside-class
policy-map DMZ6-policy
class DMZ6-class
policy-map DMZ2-policy
class DMZ2-class
policy-map DMZ5-policy
class DMZ5-class
policy-map DMZ3-policy
class DMZ3-class
policy-map DMZ10-policy
class DMZ10-class
policy-map DMZ4-policy
class DMZ4-class
suschoud Wed, 08/12/2009 - 11:03
Put in the commands below :
no class DMZ1Servers-class1
no class outside-class
no nclass DMZ6-class
no class DMZ2-class
no class DMZ5-class
no class DMZ3-class
no class DMZ10-class
no class DMZ4-class
whiteford Thu, 08/13/2009 - 05:45
Tried this, but it didn't make any difference to my upload speeds.
will.joshua Wed, 08/12/2009 - 19:19
I just posted a Conversation....I have the exact same issue.......Except for mine is download speeds....I used the same test servers you do...
paulmmacd Wed, 01/13/2010 - 10:49
We're having the same issue - twin ASA5510s in Active/Passive failover.  In front of the ASAs we can get our full 15MB, but behind them we get 1.5MB to maybe 9MB (it's all over the place but tends to be under 3MB).  We isolated one of the firewalls so our test traffic was the only traffic going through it but it made no difference.
We hired a Cisco engineer to bench the unit, wipe our configuration and test it again but he duplicated our symptoms.  The problem seems to be inherent to the unit, but even the engineer hadn't heard of the issue nor could he fix it.
I wonder if there was a bad batch that came out of manufacturing with a defect?
Kureli Sankar Wed, 01/13/2010 - 11:01
  • Cisco Employee,
Have you tried to remove threat detection and http inspection?
sh run threat
remove the lines with a "no" in front of them.
pls. check interface errors "sh int | i errors". Are you doing any kind of content scanning for the hosts that are behind the ASA? Any IDS devices monitoring the traffic? Any packet shapping devices?
Beside that we need to collect captures on ingress and egress interfaces and see where the delay is coming from.
-KS
Andy White Wed, 01/13/2010 - 11:39
I got it all fixed yesterday.
As the other post mentioned do you have any IDS infront of your firewalls or do you have the IPS modules installed in your ASA's?  In the end it was our IPS module, we had to enter the kernel mode of the IPS module using the service account and amend the /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} RegexDepth setting for the upload as is fixed for upload and for downloads it wasn't so it was sort of throttling the upload speed so we "relaxed" this.  If you need the commands I used let me know?
paulmmacd Wed, 01/13/2010 - 12:07
Andy, kusankar,
Thanks to you both for your prompt replies.  I'll try to do your effort justice with my own.
There are no IDS devices upstream from the ASAs.  I'm not sure if our ASAs have the IPS module installed, but then I don't know what the IPS module is.  A quick walk through the ASDM doesn't show anything, but there may be a difference in terminology.
I am not conversant with the IOS or working at the Cisco CLI, but I am willing to give anythng a shot.  Step-by-step instructions would be awesome.  If it makes any difference, we're running v7.2(2) of the firmware and I have v5.2(2) of the ASDM.
Thanks again for your help,
Paul
Andy White Wed, 01/13/2010 - 12:33
I would suggest upgrading your firmware at some point, 8.0.x and the lastest ASDM.  They offer lots of bug fixes plus new features, the newer ASDM (version 6.0.x) is much better.  Try 8.04 (mature) or 8.0.5 (newish).
As you are running in failover mode with 2 ASA's you can upgrade one > reload > failover to the other > upgrade > reload and there will be no downtime.  Both have to be on the save firmware for the failover to continue to work.   I can get a url on this if you need it.
The IPS module is a physical device they sits in your ASA, from the CLI on the ASA type "session 1" and see if you get a prompt.
Please rate if you find any of this helpful.
paulmmacd Wed, 01/13/2010 - 12:52
Andy,
Since the IPS module is a physical device rather than a software feature, I'm pretty sure we don't have one.  Running your command from the CLI in the ASDM returns "Card in slot 1 did not respond to session request".  When I look at the rear of the ASA, I can see an expansion slot blanking plate so I think it's safe to say I don't have an IPS module.  I take it this implies my problem is different from yours.
To be thorough, I ran the "sh int | i errors" command suggested by kusankar.  Here is the result of that:
0 input errors, 16455 CRC, 0 frame, 0 overrun, 16455 ignored, 0 abort
0 input errors, 9682983 CRC, 0 frame, 0 overrun, 9682983 ignored, 0 abort
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
So it looks like something is generating CRC errors, but that may be normal.  I ran the command multiple times and those error counts are incrementing.
Lastly, I would be very interested in any assistance you can offer upgrading the firmware on my ASAs.
Thanks again,
Paul
Kureli Sankar Wed, 01/13/2010 - 14:08
  • Cisco Employee,
Need to fix these CRC errors ASAP.
Issue sh int e0/0 or which ever is appropriate on all the interfaces and find out which interface is showing these errors.
Then see what cable connects that port to which device.  Try the following one at a time.
1. clear interface
2. set the speed and duplex to the same on both the ASA as well as the swtich end
3. change the cable
4. change the port on the swtich and watch the swtich port for errors.
after each change 2,3,4 issue sh inter | i errors.
Once you fix this you should see better results.
You are running an older code where threat detection was not introduced.
Upgrading the ASA code will not resolve the problem.  Let us first take care of the CRC errors.
-KS
paulmmacd Wed, 01/13/2010 - 14:35
kusankar,
Of the three interfaces in use - inside, outside and failover, here are the results for inside and outside:
Interface Ethernet0/0 "outside", is up, line protocol is up
  Hardware is i82546GB rev03, BW 100 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
MAC address 001b.d5e8.cbac, MTU 1500
IP address x.x.x.x, subnet mask 255.255.255.0
396474903 packets input, 79066447227 bytes, 0 no buffer
Received 2211277 broadcasts, 0 runts, 0 giants
0 input errors, 26224 CRC, 0 frame, 0 overrun, 26224 ignored, 0 abort
0 L2 decode drops
530985772 packets output, 550403493621 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (0/0) software (0/0)
output queue (curr/max blocks): hardware (0/250) software (0/0)
  Traffic Statistics for "outside":
404210359 packets input, 72160280929 bytes
530985772 packets output, 540544337897 bytes
2809681 packets dropped
      1 minute input rate 86 pkts/sec,  27165 bytes/sec
      1 minute output rate 72 pkts/sec,  12729 bytes/sec
      1 minute drop rate, 1 pkts/sec
      5 minute input rate 149 pkts/sec,  48188 bytes/sec
      5 minute output rate 186 pkts/sec,  160347 bytes/sec
      5 minute drop rate, 3 pkts/sec
Result of the command: "sh int e0/1"
Interface Ethernet0/1 "inside", is up, line protocol is up
MAC address 001b.d5e8.cbad, MTU 1500
IP address 192.168.48.1, subnet mask 255.255.255.0
548573967 packets input, 557297292042 bytes, 0 no buffer
Received 17195192 broadcasts, 0 runts, 0 giants
0 input errors, 9691710 CRC, 0 frame, 0 overrun, 9691710 ignored, 0 abort
0 L2 decode drops
392477718 packets output, 77793299669 bytes, 0 underruns
output queue (curr/max blocks): hardware (0/51) software (0/0)
  Traffic Statistics for "inside":
548573167 packets input, 547121964625 bytes
392477718 packets output, 69454135108 bytes
15357922 packets dropped
      1 minute input rate 68 pkts/sec,  17981 bytes/sec
      1 minute output rate 69 pkts/sec,  40291 bytes/sec
      1 minute drop rate, 5 pkts/sec
      5 minute input rate 190 pkts/sec,  163545 bytes/sec
      5 minute output rate 149 pkts/sec,  49707 bytes/sec
      5 minute drop rate, 5 pkts/sec
It appears the internal interface is reporting the majority of the CRC errors, but statistically the rate seems low.  The ASA in question has been up for just over 21 days and was only rebooted to troubleshoot this problem.
I will investigate the rest of your suggestions, though I'm certain the problem is in the ASA itself because we've isolated the ASA from the internal network as a matter of course while troubleshooting.  Indeed, we wiped the configuration from one ASA to make sure it wasn't the failover capability causing the problem.  In essence we ended up with a laptop on one side, our Internet connection on the other with only the ASA in the middle and still saw the problem.  Bypassing the ASA - connecting directly to the cable on the upstream side - eliminates the problem, but I'll do due diligence.
Thanks again,
Paul
Kureli Sankar Wed, 01/13/2010 - 19:21
  • Cisco Employee,
Post the output for
sh run int e0/0
sh run int e0/1
If the speed and duplex is specified in the above output make sure it matches on the switch side and set the speed and duplex manually on the switch ports.  If the switch side is set to auto, change in the above to auto as well. This should clear the CRC errors.  Once these errors are gone run your tests again.
I not sure what else everyone suggested that you change on this ASA so, it would be better you attach the current config if you have any further questions on this issue.
-KS
paulmmacd Thu, 01/14/2010 - 10:30
kusankar,
Heeding your advice, I've adjusted the switch settings for both the internal and external interfaces so they are optimal and identical between switch and ASA.  Running the "clear interface" command, then monitoring the interfaces with the 'sh int e0/0" and "sh int e0/1" commands shows no more CRC errors on either interface.
Re-running the speakeasy.net speed tests shows more symetrical, although much more varied results, including - for the first time since starting this process - an upload speed that exceeds the download speed.  While my upload speed still isn't as consistently high as my download speed, there's a definite improvement and I may be seeing the best I can get.
Here's the output of the "sh int e0/0" command:
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
2485674 packets input, 1620330786 bytes, 0 no buffer
Received 18893 broadcasts, 0 runts, 0 giants
0 L2 decode drops
2872078 packets output, 2336538828 bytes, 0 underruns
2485644 packets input, 1569397011 bytes
2872078 packets output, 2279435040 bytes
70611 packets dropped
      1 minute input rate 268 pkts/sec,  201723 bytes/sec
      1 minute output rate 294 pkts/sec,  237071 bytes/sec
      1 minute drop rate, 8 pkts/sec
      5 minute input rate 350 pkts/sec,  232823 bytes/sec
      5 minute output rate 400 pkts/sec,  307069 bytes/sec
      5 minute drop rate, 12 pkts/sec
Here's the output of the "sh int e0/1" command:
2868844 packets input, 2364562970 bytes, 0 no buffer
Received 98667 broadcasts, 0 runts, 0 giants
0 L2 decode drops
2427814 packets output, 1573194314 bytes, 0 underruns
input queue (curr/max blocks): hardware (1/0) software (0/0)
2868780 packets input, 2308033896 bytes
2427814 packets output, 1523371562 bytes
81712 packets dropped
      1 minute input rate 373 pkts/sec,  238278 bytes/sec
      1 minute output rate 377 pkts/sec,  334810 bytes/sec
      1 minute drop rate, 6 pkts/sec
      5 minute input rate 385 pkts/sec,  309956 bytes/sec
      5 minute output rate 337 pkts/sec,  217388 bytes/sec
      5 minute drop rate, 7 pkts/sec
Unless you see something in the information above, or want me to post some other bit of information, I presume this is the best we can do.
Again, my thanks to you and Andy for your respective help,
Paul
Kureli Sankar Thu, 01/14/2010 - 10:38
  • Cisco Employee,
Excellent. These look clean.
I believe with the better results that you are seeing, the issue is resolved. You probably will notice other websites loading a lot faster than before.
If there is a big diff. between the results outside the firewall and from behind the firewall pls. look at inspections and QoS if you have them configured on the ASA as well as the client NIC drivers and speed/duplex on the NIC and switch end that you are using to do the test.
Nice job.
-KS
chris-horne Thu, 09/23/2010 - 03:37
Andy,
I'm getting the same problem with upload speed maxing out at about 10Mb, while my download speed utilises almost the full 100Mb we have.  We have an ASA5510 with IPS. I've change the setting on the IPS to bypass it and this imediately resulted in an upload speed that matched the download, so it would appear that it is down to the IPS.  You mention about changing the RegexDepth setting for upload.  Can you tell me what commands I need to do this.
Chris
