WebVPN Portal Configuration
Aug 8th, 2009
I am trying to remove the auto-install function for AnyConnect that appears when anyone logs into my WebVPN portal page. We managed to set it so the viewer gets to see a page where they can cancel the setup, but I want to take that away entirely and just allow them to use a bookmark to install. So far the only way I have managed to do this was by accident. I disabled AnyConnect from the interface and the option disappeared, but that's no good.
Is it possible to disable this autorun feature and still have AnyConnect enabled?
Alar Pandis Sun, 08/09/2009 - 02:32
Hi again! My mistake, as was presumed! Local IP address pool scope was out of reach. So, I have access to NW share, but can't not yet to log into MS server, but ... I'll keep digging. I don't log during Windows startup into ... or I don't have to, so I don't need probably to start VPNgina earlier others.
More thanks, Alar.
ROBERT CROOKS Mon, 08/10/2009 - 04:05
Maybe you misunderstand my problem. It isn't anything to do with Windows, it's the config on my ASA 5510 portal customization.
Alar Pandis Mon, 08/10/2009 - 04:23
Hi! Sorry, I can't understand how this my message earlier got here! It supposed to be on different thread. Sorry.
