1524 AP Question
Aug 8th, 2009
"Need help to resolve a configuration. AP1524 have 03 and need to linking (4,9-5.8 Ghz) in a straight line, are at a distance of half a mile of each other. The first AP (Rap) is fed with a WLC, it must bind to the second AP (MAP) and the second link to the third AP ((MAP), each serving in the 2.4 users. I doubt whether such a configuration works. In the case of antennas operate ¿What should I use?"
pradeepde Thu, 08/13/2009 - 09:03
When designing and building a wireless mesh network here are a few system characteristics to consider. Some of these apply to the backhaul network design and others to the CAPWAP controller design:
•Recommended backhaul is 24 Mb/s
-24 Mb/s is chosen as the optimal backhaul rate because it aligns with the maximum coverage of the WLAN portion of the client WLAN of the MAP; that is, the distance between MAPs using 24 Mb/s backhaul should allow for seamless WLAN client coverage between the MAPs.
-A lower bit rate might allow a greater distance between mesh access points, but there are likely to be gaps in the WLAN client coverage, and the capacity of the backhaul network is reduced.
-An increased bit rate for the backhaul network either requires more mesh access points or results in a reduced SNR between mesh access points, limiting mesh reliability and interconnection.
-The wireless mesh backhaul bit rate (set on the controller), like the mesh channel, is set by the RAP.
"Cisco Aironet 1520, 1130, 1240 Series Wireless Mesh Access Points, Design and Deployment Guide, Release 5.2":
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
