smalkeric Fri, 08/14/2009 - 14:01
  • Silver, 250 points or more
You can backup and restore the Security Manager database using Common Services. From the Backup page you can schedule immediate, daily, weekly, or monthly automatic backups. This is accessible from the Tools menu by selecting Tools > Backup. For more information, click Help from the Common Services Backup page. Restoration of Security Manager database and data files is supported only by running a script on the command line.
http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.1/user/guide/adman.html#wp1096292
jan.nielsen Sat, 08/15/2009 - 13:48
  • Gold, 750 points or more
I think what you wanted was a backup of the asa config, not a csm backup right ? Well, unless you make changes in the CLI, csm will always have the most recent config, as all changes are published and saved by csm
tech_trac Sun, 08/16/2009 - 04:40
Yes. I would like to do backup of ASA configs through CSM application.
How can I view the configuration saved by CSM i.e. through GUI as well as text file on the Windows file system.
Thanks.
