Web Authentication - Web login page not displayed
BrianJ2007
Cisco 4402 WLC running version 5.2.193.0
Access Points: AIR-LAP1142N
I have configured an SSID for WebAuthentication. When a wireless client logs into the WLAN the PC will associate to the AP but will then stop at the WEBAUTH_REQD stage.
Internet Explorer will show the attmept to redirect to the virtual port at 1.1.1.1 but will not bring up the login page.
IE shows : https://1.1.1.1/login.html?redirect=www.google.co.ukhttp://www.google.co.uk/
The network is a flat network so this SSID is using the management interface.
DHCP is being provided by the controller for this WLAN.
I know the classic design should be for this to be implemented on a separate VLAN but my customer has not VLANed his network yet and this is planned at a later stage. I have implemented this on a flat network before and it has worked.
Any suggestions would be much appreciated.
BrianJ2007
Important bit of information left of the original entry.
Debug Client results in the following message for every attempt to log onto the WLAN:
Orphan Packet from 10.0.0.55 on mobile
Where 10.0.0.55 is the IP address of the laptop.
zhenningx
Level 4
Level 4
Can you client resolve DNS properly? If cannot resolve DNS, web auth page cannot load.
If the client is going through a proxy server, put virtual interface IP (eg. 1.1.1.1) in proxy exception of client LAN settings
harsisin
I faced exactly the same problem as you have described above. The following is what fixed it for me, i am sure u try it to might fix it for u as well.
In my scenario i found that my WLC controller had cipher-option sslv2 disabled. I enabled it and that resolved the issue for me.
This is what needs to be done in order to do it :-
It's best to enable it on the WLC and this is done from the CLI. It requires a reboot.
ssh to the WLC
enter the following command:-
WLC>config network secureweb cipher-option sslv2 enable
and then reboot.
Once the WLC reboots u can check the status by issuing the following command:-
WLC>show network summary
The output should look similar to the following
RF-Network Name............................. GTCR-CH-RF-GA
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
As u can see the Secure Web Mode Cipher-Option SSLv2 is now enabled.
This should work.
Hope this helps and all the best.
