Selecting FXO port from H.323
Aug 9th, 2009
I have a scenario like 2 local extension 1001 and 1002. and i have 2 Analog line connected to FXO fro eg: A and B. I was asked to configure that if i make call from 1001 to outside my call has to go through FXO line A and from 1002 it has to go to FXO B. As Gateway is configured as H.323 how can i do this set up?
Overall Rating: 4 (1 ratings)
Nicholas Matthews Sun, 08/09/2009 - 06:55
You can do this all on the gateway.
You can create different incoming dial peers, that look like this:
dial-p v 1 voip
answer-address 1001
translation-profile (adds a 955 to beginning of called number)
dial-p v 2 voip
answer-address 1002
translation-profile (adds a 966 to beginning of called number)
dial-p v 3 pots
port 0/0/0
destination-pattern 955.T
dial-p v 4 pots
port 0/0/1
destination-pattern 966.T
That would do it. Alternatively, you could add the prefixes in CUCM by creating different route patterns with different partitions and adding different digits there.
-nick
