08-09-2009 12:23 PM - edited 03-04-2019 05:41 AM
We have connected two of our branches using a bundle of two T1s, using two Cisco 2610 routers, with a dual T1 WIC-T1 card on each one of them. However, I feel that there is something wrong with my configurations since we are not getting a fast/reliable throughput. I noticed a lot of packet lost when I ping a device from one side to the other side. I have included both routers configuration. Please comment on anything that could improve the communication. Thank you,
Ellsworth-R#sh config
Using 2020 out of 29688 bytes
version 12.3
hostname Ellsworth-R
boot-start-marker
boot-end-marker
enable password ********
clock timezone ES -5
no aaa new-model
ip subnet-zero
ip cef
ip name-server 10.31.1.180
no ip bootp server
controller T1 0/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24 speed 64
controller T1 0/1
framing esf
linecode b8zs
interface Multilink1
ip address 10.31.100.21 255.255.255.252
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface Ethernet0/0
description connected to local subnet 10.31.1.X
ip address 10.31.6.2 255.255.255.0
ip route-cache flow
full-duplex
interface Serial0/0:1
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no fair-queue
ppp multilink
interface Serial0/1:1
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no fair-queue
ppp multilink
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.31.100.22
access-list 100 permit ip any any dscp cs7
access-list 101 permit ip any any dscp cs6
access-list 102 permit ip any any dscp cs5
access-list 103 permit ip any any dscp cs4
access-list 104 permit ip any any dscp cs3
access-list 105 permit ip any any dscp cs2
access-list 106 permit ip any any dscp cs1
access-list 107 permit ip any any dscp default
priority-list 1 protocol ip high list 100
priority-list 1 protocol ip high list 101
priority-list 1 protocol ip medium list 102
priority-list 1 protocol ip medium list 103
priority-list 1 protocol ip normal list 104
priority-list 1 protocol ip normal list 105
priority-list 1 protocol ip low list 106
priority-list 1 protocol ip low list 107
line con 0
login
line aux 0
password ********
line vty 0 4
exec-timeout 30 0
password ********
login
end
Ellsworth-R#
see the next post for the second router's configuration
Solved! Go to Solution.
08-09-2009 01:28 PM
Any reason for having fragmentation disabled on the ppp multilink?
According to the usage guidelines, this command can cause performance degradation;
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_p2.html#wp1013306
Also, why are you limiting 26 packets in the transmission ring? Having more packets in the ring (default is 60) will improve the router's throughput.
I also recommend removing the tx-queue limit as an incorrect value can produce adverse results - best to leave it as default and let the physical interface dictates its limit.
HTH,
__
Edison.
08-09-2009 12:24 PM
Second Router's configuration:
Main_to_Ells#sh config
Using 3399 out of 29688 bytes
version 12.3
hostname Main_to_Ells
boot-start-marker
boot-end-marker
enable secret 5 $1$67dJ$rfd2sWrP4OuyIBn9rjH4U/3ln1
no aaa new-model
ip subnet-zero
ip cef
no ip bootp server
controller T1 0/0
framing esf
linecode b8zs
controller T1 0/1
framing esf
linecode b8zs
ip address 10.31.100.22 255.255.255.252
no cdp enable
ppp multilink
ip address 10.31.1.2 255.255.255.0
ip route-cache flow
full-duplex
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ppp multilink
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ppp multilink
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.31.1.1
ip route 10.1.1.0 255.255.255.0 10.31.1.253
ip route 10.1.2.0 255.255.255.0 10.31.1.253
ip route 10.31.2.0 255.255.255.0 10.31.1.1
ip route 10.31.3.0 255.255.255.0 10.31.1.1
ip route 10.31.4.0 255.255.255.0 10.31.1.1
ip route 10.31.5.0 255.255.255.0 10.31.1.1
ip route 10.31.6.0 255.255.255.0 10.31.100.21
ip route 170.209.0.2 255.255.255.254 10.31.1.30
ip route 192.168.237.0 255.255.255.0 10.31.1.253
ip route 192.168.244.0 255.255.255.0 10.31.1.253
ip route 206.104.53.132 255.255.255.255 10.31.1.253
ip route 206.104.53.142 255.255.255.255 10.31.1.253
ip route 206.104.53.143 255.255.255.255 10.31.1.253
ip route 206.104.53.144 255.255.255.255 10.31.1.253
ip route 206.104.53.145 255.255.255.255 10.31.1.253
ip route 206.104.53.146 255.255.255.255 10.31.1.253
ip route 208.75.53.5 255.255.255.255 10.31.1.253
ip route 208.75.53.6 255.255.255.255 10.31.1.253
ip route 208.75.53.7 255.255.255.255 10.31.1.253
ip route 208.75.53.8 255.255.255.255 10.31.1.253
ip route 208.75.53.9 255.255.255.255 10.31.1.253
ip route 208.75.53.10 255.255.255.255 10.31.1.253
ip route 208.75.54.66 255.255.255.255 10.31.1.253
ip route 208.75.54.67 255.255.255.255 10.31.1.253
ip route 208.75.54.68 255.255.255.255 10.31.1.253
ip route 208.75.54.69 255.255.255.255 10.31.1.253
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.244.0 0.0.0.255
line con 0
login
line aux 0
line vty 0 4
password ******
login
end
Main_to_Ells#
08-09-2009 01:28 PM
HTH,
__
Edison.
08-09-2009 01:46 PM
THANK you Edison,
per your recommendation I have removed the lines that you mentioned above and now the configuration looks like below on both ends:
no cdp enable
ppp multilink
ip route-cache flow
full-duplex
no ip address
encapsulation ppp
ip route-cache flow
no keepalive
no fair-queue
ppp multilink
no ip address
encapsulation ppp
ip route-cache flow
no keepalive
no fair-queue
ppp multilink
However, I'm still losing ping pakets whe I ping a divice across as shown below:
Reply from 10.31.6.180: bytes=32 time=18ms TTL=126
Request timed out.
Reply from 10.31.6.180: bytes=32 time=112ms TTL=126
Request timed out.
Request timed out.
Request timed out.
Reply from 10.31.6.180: bytes=32 time=32ms TTL=126
Reply from 10.31.6.180: bytes=32 time=48ms TTL=126
Reply from 10.31.6.180: bytes=32 time=35ms TTL=126
Reply from 10.31.6.180: bytes=32 time=40ms TTL=126
Reply from 10.31.6.180: bytes=32 time=72ms TTL=126
Reply from 10.31.6.180: bytes=32 time=55ms TTL=126
Reply from 10.31.6.180: bytes=32 time=41ms TTL=126
Request timed out.
Request timed out.
Reply from 10.31.6.180: bytes=32 time=118ms TTL=126
Request timed out.
Reply from 10.31.6.180: bytes=32 time=45ms TTL=126
Request timed out.
Request timed out.
Reply from 10.31.6.180: bytes=32 time=7ms TTL=126
Request timed out.
Request timed out.
Reply from 10.31.6.180: bytes=32 time=121ms TTL=126
Reply from 10.31.6.180: bytes=32 time=67ms TTL=126
Request timed out.
Request timed out.
Reply from 10.31.6.180: bytes=32 time=81ms TTL=126
Reply from 10.31.6.180: bytes=32 time=36ms TTL=126
Request timed out.
Reply from 10.31.6.180: bytes=32 time=9ms TTL=126
Reply from 10.31.6.180: bytes=32 time=63ms TTL=126
Request timed out.
Reply from 10.31.6.180: bytes=32 time=49ms TTL=126
Reply from 10.31.6.180: bytes=32 time=25ms TTL=126
Reply from 10.31.6.180: bytes=32 time=29ms TTL=126
Request timed out.
Reply from 10.31.6.180: bytes=32 time=26ms TTL=126
Reply from 10.31.6.180: bytes=32 time=17ms TTL=126
Reply from 10.31.6.180: bytes=32 time=31ms TTL=126
Reply from 10.31.6.180: bytes=32 time=62ms TTL=126
Request timed out.
Request timed out.
Request timed out.
Reply from 10.31.6.180: bytes=32 time=93ms TTL=126
Reply from 10.31.6.180: bytes=32 time=54ms TTL=126
Reply from 10.31.6.180: bytes=32 time=130ms TTL=126
Request timed out.
08-09-2009 03:06 PM
Can you post the output from typing
show proc cpu sorted
show proc cpu his
show interface Serial0/0:1
show interface Serial0/1:1
from both routers.
Also, try pinging from multilink to multilink IP, do you get request time out then?
TTL=126 seems a bit odd.
__
Edison.
08-09-2009 04:08 PM
Edison, Thanks for looking into this, I have to post it in three section due to the size limitation- Here you go:
Main_to_Ells#show interface serial 0/0:1
Serial0/0:1 is up, line protocol is up
Hardware is PowerQUICC Serial
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 177/255, rxload 7/255
Encapsulation PPP, LCP Open, multilink Open, loopback not set
Keepalive not set
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 05:15:50
Queueing strategy: priority-list 1 [suspended, using FIFO]
Output queue (queue priority: size/max/drops):
high: 0/20/0, medium: 0/40/0, normal: 0/60/0, low: 0/80/0
5 minute input rate 45000 bits/sec, 64 packets/sec
5 minute output rate 1069000 bits/sec, 182 packets/sec
1005461 packets input, 70427156 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
4 input errors, 0 CRC, 4 frame, 0 overrun, 0 ignored, 0 abort
2457898 packets output, 2451140888 bytes, 0 underruns
0 output errors, 0 collisions, 10 interface resets
1 carrier transitions
Timeslot(s) Used:1-24, SCC: 1, Transmitter delay is 0 flags
Main_to_Ells#show interface serial 0/1:1
Serial0/1:1 is up, line protocol is up
reliability 255/255, txload 176/255, rxload 6/255
Keepalive not set
Last clearing of "show interface" counters 05:16:15
5 minute input rate 40000 bits/sec, 62 packets/sec
5 minute output rate 1061000 bits/sec, 179 packets/sec
1006206 packets input, 70497417 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 1 giants, 0 throttles
126 input errors, 8 CRC, 111 frame, 0 overrun, 0 ignored, 7 abort
2449709 packets output, 2445243413 bytes, 0 underruns
Timeslot(s) Used:1-24, SCC: 2, Transmitter delay is 0 flags
Main_to_Ells#
08-09-2009 04:09 PM
Main_to_Ells# show processes cpu history
Main_to_Ells 12:15:14 AM Monday Mar 1 1993 ES
2222222222222222222333331111111111111111111111111222221111
0000888884444422222000008888888888666668888833333333339999
100
90
80
70
60
50
40
30 ***** *****
20 ******************************************** ***********
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
22323223222233322322233233333323333322212231111 222
9614386326880308519392068349318541007306540885633212324241
100
90
80
70
60
50
40 * * *
30 *** **** ********** ******##****#**#* * *
20 #######################################**##**** *###*
10 ############################################### #####
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
35448
96575
100
90 *
80 *
70 *
60 * *
50 ****
40 *****
30 *****
20 ##***
10 #####
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
08-09-2009 04:11 PM
CPU utilization for five seconds: 19%/17%; one minute: 21%; five minutes: 21%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
10 38203 38851 983 0.39% 0.20% 0.16% 0 ARP Input
35 50505 65535 770 0.31% 0.22% 0.19% 0 IP Input
64 396 122 3245 0.23% 0.38% 0.10% 66 Virtual Exec
46 3085 522 5909 0.15% 0.01% 0.00% 0 IP Background
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 4 7 571 0.00% 0.00% 0.00% 0 Serial Backgroun
8 0 2 0 0.00% 0.00% 0.00% 0 AAA high-capacit
9 0 630 0 0.00% 0.00% 0.00% 0 Environmental mo
4 9997 2008 4978 0.00% 0.01% 0.01% 0 Check heaps
5 0 2 0 0.00% 0.00% 0.00% 0 Pool Manager
12 8 8 1000 0.00% 0.00% 0.00% 0 DDR Timers
2 0 3770 0 0.00% 0.00% 0.00% 0 Load Meter
14 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
15 16 18844 0 0.00% 0.00% 0.00% 0 GraphIt
16 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
1 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
11 24 3770 6 0.00% 0.00% 0.00% 0 HC Counter Timer
19 132 4971 26 0.00% 0.00% 0.00% 0 Net Background
13 8 2 4000 0.00% 0.00% 0.00% 0 Entity MIB API
21 76 18807 4 0.00% 0.00% 0.00% 0 TTY Background
22 76 18851 4 0.00% 0.00% 0.00% 0 Per-Second Jobs
23 4 2 2000 0.00% 0.00% 0.00% 0 SM Monitor
17 0 2 0 0.00% 0.00% 0.00% 0 SMART
25 0 1 0 0.00% 0.00% 0.00% 0 dev_device_remov
26 1198 6294 190 0.00% 0.00% 0.00% 0 Net Input
27 0 3771 0 0.00% 0.00% 0.00% 0 Compute load avg
28 9014 315 28615 0.00% 0.05% 0.00% 0 Per-minute Jobs
29 36 75375 0 0.00% 0.00% 0.00% 0 e1t1 Framer back
30 0 2 0 0.00% 0.00% 0.00% 0 AAA Server
31 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
32 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
18 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
34 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
20 4 69 57 0.00% 0.00% 0.00% 0 Logger
36 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
37 656 2469 265
08-09-2009 04:15 PM
This is crazy it won't let me to copy and past stuff. I guess there is a limitation. can i email you all of that if that is the case send you email to me and i will reply with all the infor here is my email: """essi@boaa.com"""
08-09-2009 04:59 PM
Ellsworth-R#ping 10.31.100.22
Sending 5, 100-byte ICMP Echos to 10.31.100.22, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/19/32 ms
Ellsworth-R#
Main_to_Ells#ping 10.31.100.21
Sending 5, 100-byte ICMP Echos to 10.31.100.21, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/12/16 ms
Main_to_Ells#ping 10.31.100.22
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/25/32 ms
Main_to_Ells#
08-10-2009 05:11 AM
Can you send more than 4 icmp packets from the router to router connection and try to increase the size of the packet to a larger value - say 900?
As for copy and paste on these forums, there is a limit which you can circumvent by pasting the entire content onto notepad and upload the file.
If you come back with no packet lost from router to router, we need to investigate your LAN environment at both locations. That TTL count that you posted previously is quite abnormal for a point-to-point site interconnection. Can you post a traceroute from that same device while targeting the same destination?
08-10-2009 06:33 AM
08-10-2009 07:14 AM
Looking at your interfaces, you have an alarming count of input errors in all interfaces (including the LAN interface) on the Ellsworth-R router.
E0/0
21877392 packets input, 4152764533 bytes, 0 no buffer
Received 1019873 broadcasts, 0 runts, 0 giants, 0 throttles
110051 input errors, 109951 CRC, 0 frame, 0 overrun, 100 ignored
Serial interfaces
S0/0:0
18362420 packets input, 1006175883 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 13 giants, 0 throttles
34491294 input errors, 1126098 CRC, 33345521 frame, 0 overrun, 240 ignored, 19675 abort
S0/1:1
18223028 packets input, 804705597 bytes, 0 no buffer
Received 0 broadcasts, 1 runts, 824 giants, 0 throttles
34685830 input errors, 1120534 CRC, 33404118 frame, 0 overrun, 391 ignored, 161178 abort
Same on Main_to_Ells Router:
E0/0
5 minute output rate 54000 bits/sec, 67 packets/sec
10828503 packets input, 1890964668 bytes, 0 no buffer
Received 529504 broadcasts, 0 runts, 0 giants, 0 throttles
539895 input errors, 539880 CRC, 85720 frame, 0 overrun, 15 ignored
________
The LAN cabling needs to be verified. What type of device is connected to each of these routers?
On the Serial errors, you need to contact your provider.
__
Edison.
08-10-2009 12:12 PM
at the both end the Ethernet ports are connected to a 3Come 4400 LAN Switch. Since you mentioned the cabling they are connected using a normal stright RJ45 cables. Do you want me to swap the cables with any other model/version? I have just opend a new ticket with the service provider to come and check the SmartJak and run a test end to end again to see what they may discover.
08-10-2009 01:00 PM
I suggest swapping cabling and verify both devices are running compatibles speed/duplex setting.
I see you are running full duplex on the cisco router, make sure the switches are also set to full duplex.
__
Edison.
