Cant get ISDN Layer 1 active even getting a tone on ISDN
Answered Question
Aug 9th, 2009
HI i am configuring ISDN line on cisco 2821....The problem is that even though i get a tone but when i put the line in my router i am seeing my Layer 1 as Deactivited
Kindl see the attached Logs and see if i am doing anything wrong .Moreover the config for the BRi interface are below
interface BRI1/0
ip address 192.168.1.1 255.255.255.252
encapsulation ppp
dialer idle-timeout 2147483
dialer string 00942212121
dialer load-threshold 1 either
dialer-group 3
isdn switch-type basic-net3
isdn point-to-point-setup
ppp authentication pap callin
ppp pap sent-username abc password 0 acb
Correct Answer by Wilson Samuel about 7 years 7 months ago
Hi Waqas,
Unless the L-1 is Activated, and functional all other attempts to make this work are futile.
I would want to speak with the Telco and or if you happen to have a TA (since its a BRI) would like to check if the phone is working on the ISDN.
Wilson Samuel
Overall Rating: 5 (1 ratings)
Correct Answer
Wilson Samuel Mon, 08/10/2009 - 04:56
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Hi Waqas,
Wilson Samuel
waqas0612147 Mon, 08/10/2009 - 06:37
Dear Wilson
Yes i can make a call from the Telephone on the ISDN but as far as Telco is concerned they are assuring me that every thing is fine from their end .....so as you r suggesting that i should again confirm from Telco company.
Waqas
Paolo Bevilacqua Mon, 08/10/2009 - 07:53
  • Hall of Fame,
    Founding Member
Anywhere except North America, it is normal to have L1 de-activated all the time except when a call is in progress, and a sh0ort time thereafter.
Also, having a BRI doesn't necessarily involve having a TA (Terminal Adapter), although likely you will have an NT (Network Terminator).
Sometime IOS is plain buggy and you need to replace image to have it working.
