SNMP-MIB-ASA 5505-IPSEC and IKE tunnel
Aug 9th, 2009
Dear All,
Is it possible to monitor the number of IPSEC and IKE tunnel sessions and individual tunnels through a NMS(Solarwinds€). If yes what would be the SNMP MIB suitable to Cisco Adaptive Security Appliance Software Version 7.2(4) Device Manager Version 5.2(4)
Where can find the same.
robertson.michael Mon, 08/10/2009 - 05:18
Hi Shibu, will give you a list of the active IPSEC tunnels. This is the only MIB I have used in the past.
Hope that helps.
merabtavart Fri, 07/22/2011 - 01:51
Advantage   of VPNTTG over other SNMP based monitoring software’s is  following:   Other (commonly used) software’s are working with static OID  numbers,   i.e. whenever tunnel disconnects and reconnects, it gets  assigned a  new  OID number. This means that the historical data, gathered  on the   connection, is lost each time. However, VPNTTG works with VPN  peer’s  IP  address and it stores for each VPN tunnel historical  monitoring  data  into the SQL server and into the RRD (Round Robin  Database) file.
