Tacaus+ & VPDN
Aug 10th, 2009
How i can configure source based authenticaiton for tacaus .......
int fa0
ip add
ip add secondary
I want source IP for authentication should be network ....
And another VPDN Que
vpdn-group 1
request dialin
protocol l2f
domain philzone.com
initiate-to ip
local name unbrokenchain
authen before-forward
What is exact use of command
initiate-to ip
I want that when ever user will dial from specific Public IP then only he should get connected to my Private network ..........
Provide me configuration .........
mchin345 Fri, 08/14/2009 - 07:39
You can designate a fixed source IP address for all outgoing TACACS packets. The feature enables TACACS to use the IP address of a specified interface for all outgoing TACACS packets. This is especially useful if the router has many interfaces, and you want to make sure that all TACACS packets from a particular router have the same IP address.
