Losing ntp source lookback config after router reload
Aug 10th, 2009
We are seeing bug CSCsx21595:
Symptom:
Conditions:
Losing the config after reload/upgrade to 124(23.15)T2
Workaround:
Manually readd the config back
We are running c2800nm-advsecurityk9-mz.124-24.T1.bin on our 2811 router.
We can't see 12.(24.6)T1 on Cisco Systems which is supposed to address the above bug:
iyde Mon, 08/10/2009 - 03:39
Hi Alphonse.
Cisco does not publisize the so-called interim releases, which are releases where the number in parathesis is with a decimal, i.e. like (24.6) as you write. You will either have to wait until the next 12.4T maintenance release is out or if you need the interim urgently you will have to ask through TAC.
