LAN encrption
Aug 10th, 2009
Dear all
I have a corporate LAN
I want to encrypt my packets between my cisco switch ports.
please give your hints
cisco24x7 Mon, 08/10/2009 - 05:49
1- Use SSL,
2- Use SSH
that will encrypt all traffics inside your corporate LAN, independent of your network.
Rick Morris Mon, 08/10/2009 - 07:32
Forgive me for asking this, but why are you wanting to encrypt internal traffic between switch ports?
Is it because of information between or within departments? Instead of that why would you not just create VLAN for the separate departments and then ACL the traffic, no access is granted outside the VLAN unless by the ACL.
What are you trying to accomplish?
hani-molani Mon, 08/10/2009 - 10:43
this is for specific solution
its mandatory to encrypt packet while traveling between endpoints and clients
Tony.henry Tue, 08/11/2009 - 11:50
Hani,
I think you should be looking at the endpoints to do the encryption/ decryption, and the cisco gear to carry the traffic.
As another poster responded SSH/SSL. will happily encrypt the payload.
Tony
Hani,
Tony
Collin Clark Tue, 08/11/2009 - 12:37
We also have certain areas that require encryption. Layer 2 ports can't do it today and between multiple subnets would be a nightmare. Have the OS perform the encryption.
